- Acorn Computers Ltd (2006) dissolved (Gen:147)
- Awesome website of the minute (PP:11)
- LCD Monitor Defs for Risc PC (Gen:13)
- Don't forget to change your clocks... (Site:9)
- Another wanted! A5000 Ethernet podule. (Gen:1)
- VNC server (Prog:12)
- UniPod USB stick support (Gen:9)
- SWIV-a-like (Games:41)
- RO 3.5 to 3.7 upgrade procedure (Gen:25)
- Experience with A9home? (Gen:42)
Choice of algorithm
Implementation
Figure 1
Figure 2
Initial problems
Figure 3
Road weighting
Implementation details
typedef struct _road_path {
  int l;
  struct _road_path *next;
  corner *c;
  struct _road_path *lnext;
} road_path;
Tweaking and improvements
Figure 4
Figure 5
