- Will we see 5.30 released at Wakefield show? (News:)
It is often a good idea to leave a cache of heavier weaponry somewhere on a level which you can return to, and face enemies carrying far less. Dropping things like heavy missiles and huge mines is highly reccommended, as they impede progress somewhat. A good way to take on large groups of enemies is to simply carry a minigun and a few spare rounds. Staying below 90Kg is highly reccommended.
Stimpacks become less useful the higher your health is, so don't use them when above 150 health, as you only get 5 health for each. Whilst on a lower value, eg 10, you get up to 50 each.
Running away from people is not a bad idea, as you can often get around a corner and lay a couple of traps. This is particularly useful against the larger missile launching dinosaurs. Also remember that bouncy projectiles can be bounced off walls and around corners.
