- Battle for Wesnoth (Games:2)
- Dwarf Fortress (Games:31)
- What's your next computer? (Gen:57)
- Last of the Iyonix (Gen:17)
- !Hamsters Sound Track now Available in HQ MP3.. (Games:2)
- TIB's NintendoDS Community Meeting Place Thing Doodah (Games:1087)
- I hate Windows safe mode (PP:14)
- Old Interactive Fiction... (Games:6)
- 22" Widescreen TV/Monitor (Gen:6)
- An I also hate useles bloody banks (PP:3)
The Icon Bar: News and features: Random map generators
Posted by Jeffrey Lee on 15:00, 9/1/2007 | , ,
Rogue
Rogue 3.6
Rogue 3.6
Elite
Elite local map
Elite local map
Elite is perhaps the second oldest and well-known example of random map generation. Although the layout of the Elite galaxies is identical each time you play, this doesn't change the fact that it was all generated by a computer (see here). As the game loads, a map generator using a fixed seed is used to generate the locations and types of the solar systems. This algorithm was used for several reasons - not only did it save important development time, but it also helped to give the world a 'natural' and 'random' feel that would have been almost impossible to obtain by hand. I suspect that memory constraints also played an important role - being able to generate galaxies on-the-fly would free up valuable bytes, and using an algorithm as opposed to pre-generated data would also allow the game to run without tape or disk access once fully loaded.
Many other space-based games use or used random map generators, including Exodus (Each time you start a new game), and the MMORPG EVE Online (When the initial layout and content of the galaxy was generated, see here).
Strategy games
SimCity terrain
SimCity terrain
Real-time and turn-based strategy games also take advantage of random map generators. For example, SimCity games use a random terrain generator to create the initial landscape when you start a new city, and the Heroes of Might and Magic 2 level editor can generate a fully random map for immediate play (Although it is unlikely to be well-balanced for multiplayer).
First person shooters
A simple Slige level
With the advent of Doom and Quake, attempts were made to produce map generators for first person shooters. With a more freeform environment of polygons and surfaces (as opposed to a regular grid of map tiles, or fairly arbitrary coordinates in space), more advanced algorithms were required. Not only do the maps need to be valid, but they also needed to look pretty, and be possible to complete (e.g. enough health and ammo for the player, any locked doors must have an accessible key, and all corridors must be wide enough for the player to fit through).
An example
The anatomy of a room
  1. The generator is initialised with the width and height of the map to generate, and the number with which to seed the random number generator
  2. A single room, the size of the map, is created, and placed in an 'active' room queue
  3. For each room in the 'active' queue, that room is subdivided. It can either be divided horizontally or vertically, and the division point is chosen randomly. However if either of the child rooms is too small (Less than 3 cells wide or deep), the room will be left alone and moved to the 'inactive' queue. If the division succeeded, the two new rooms will be added to the 'active' queue - thus these two new rooms will be subdivided again at a later point in time.
  4. Once the 'active' queue is empty, the map will contain a series of simple rectangular rooms. A random number of those rooms are now selected for 'joining' - each selected room will be joined with a random neighbour, and then with another neighbour, etc. to produce irregular shaped rooms and corridors. In the current implementation, every tenth room of the map will be merged with 3 of its neighbours.
  5. The next stage is to link all the rooms with doors so that it's possible for the player to visit every room in the map. First, every room is marked as 'unlinked', and all the edges are set to type 'wall'. Then:
    1. An arbitrary room is selected and marked as 'linked'
    2. From that room, a graph traversal algorithm is activated, travelling to each adjacent room that has a 'door' edge between it and the current room. Each room is marked as 'linked' as it is visited.
    3. If all rooms have become marked as 'linked', then the algorithm stops.
    4. Else a 'wall' edge is selected at random and changed to a 'door' edge.
    5. If that edge happened to be on the boundary between a 'linked' room and an 'unlinked' room, go to step 2, continuing the graph traversal in the newly-linked room. Else, go to step 4.
    Edges are chosen for door conversion at random so that the resulting map is still random. It's possible to write other algorithms - for example only choosing edges that lie on the boundary between a linked room and an unlinked room - but that will reduce the randomness of the layout (In fact, it will produce a traditional maze in which there is only one path to the exit).
  6. The next step is to choose the start and end point for the level. I wanted these points to be as far apart as possible. To do this I could have simply placed them in rooms at opposite corners of the map, but I decided to write a real algorithm for it instead:
    • Firstly, a room is selected at random.
    • Then, the furthest room from that room is selected (based around the number of doors that must be travelled through). This will be the start point of the level, and will most likely be a room near a corner of the map.
    • Finally the furthest room from that room will be selected, which will be made the exit room of the map. This is most likely to be in the opposite corner of the map to the first room.
  7. Locked doors and keys are then added to the map. Unfortunately all my algorithms for this have produced buggy levels, which can leave the player trapped if they take the wrong turning (Since each key is consumed when used to open a door).
    If you look at the source code to GAIO, you can see two different algorithms I've tried writing for door and key placement, along with a verification algorithm that fails to verify the maps properly.
  8. The next step is to add monsters and items. Currently these are placed randomly, although future versions will choose the correct item distribution based around the chosen difficulty level and the types of monster present. If you clicked on the image above, you'll have seen that the map already contains some monsters. That's because they are also added by the previous step, to all rooms immediately behind a locked door.
  9. The final step is to copy the list of rooms and edges into a 2D grid of map tiles. This grid is used by the game for rendering and collision detection. A lookup table is also kept, which will allow the game to instantly calculate what room an object is in based around its coordinates.
  pnaulls (15:22 9/1/2007)
  nunfetishist (17:12 9/1/2007)
    monkeyson2 (17:20 9/1/2007)
      VincceH (18:57 9/1/2007)
        SimonC (11:29 10/1/2007)
          Phlamethrower (11:37 10/1/2007)
            Loris (18:28 19/1/2007)
              Phlamethrower (18:48 19/1/2007)
  flypig (18:50 9/1/2007)
Peter Naulls Message #96888, posted by pnaulls at 15:22, 9/1/2007
You missed out a classic type - random terrain generators - usually just for the effect rather than any game. One appear in Acorn User many moons ago, and others can be seen in screen savers.
Rob Kendrick Message #96892, posted by nunfetishist at 17:12, 9/1/2007, in reply to message #96888
Exposing morons since 1981
Wasn't the universe in Elite also randomly generated, to save space?
Phil Mellor Message #96894, posted by monkeyson2 at 17:20, 9/1/2007, in reply to message #96892
The trouble with random/automagic content is that you can lose interest in playing with it once you realise how it works. I never got into Elite because it was too much like playing against a random number generator - yet I rarely felt that with Angband.
David Llewellyn-Jones Message #96902, posted by flypig at 18:50, 9/1/2007, in reply to message #96888
Interesting article :) Even though GAIO is still in progress, I find it surprisingly addictive wandering around the corridors.
http://forums.introversion.co.uk/introversion/viewtopic.php?t=586
VinceH Message #96903, posted by VincceH at 18:57, 9/1/2007, in reply to message #96894
VincceH
Heh - like the Space Invaders console my uncle had when I was a kid; we spent a while doing it, but we eventually worked out how to get maximum points from the seemingly random points awarded for shooting the UFO; it was something along the lines of after firing the first 23 shots, don't fire any more until the UFO appears, and use the 24th to shoot that, and thereafter for the level, it would be the 16th shot.
What fun. :)
Properly designed screens were more appropriate for the final game, though - but I'm not entirely sure if I removed the random map logic from the program. If anyone still has the original version it might be worth looking. (That said, it was a nasty mess of BASIC, including GOTOs and everything, so maybe not!)
Simon Challands Message #96929, posted by SimonC at 11:29, 10/1/2007, in reply to message #96903
Elite
Right on, Commander!
On and off for a while I've been trying to come up with a suitable random terrain generator to get a realistic landscape (i.e. proper valleys and ridges and generally Lake District-type topography) for my almost certainly will never be written mining simulator. In the unlikely event I succeed there I'll then have to move on to randomly generated geology.
Jeffrey Lee Message #96932, posted by Phlamethrower at 11:37, 10/1/2007, in reply to message #96929
Sometime soon I'm hoping to write my own city generator.
Tony Haines Message #97449, posted by Loris at 18:28, 19/1/2007, in reply to message #96932
madbanHa ha, me mine, mwahahahaha
For a long time now this has been a fascination of mine. I think it is a rather different proposition to create an interesting 'randomly seeded' but fixed level, like Exile's, than a landscape generator. For two related reasons.
Firstly, it has much more of a bearing on the gameplay than a simple landscape does. And secondly, because it uses an algorithm which allows a 'keyhole' of the level to be generated, rather than an interacting structure which requires effectively the whole level to be generated and held in memory in order to view any bit.
Exile is particularly interesting in that the level is effectively defined by the algorithm, rather than through the random seeds supplied. (Although in theory the two may be effectively the same, in practical programming terms they are not.)
I've been thinking about writing an article on this subject for a while, but would like to write my own level generator to back it up. Actually I did write a simple one, putatively for a small coding competition, but never got round to populating it with monsters.
Jeffrey Lee Message #97450, posted by Phlamethrower at 18:48, 19/1/2007, in reply to message #97449
Well, feel free to send it to us for publishing once it's finished :)
