- AMCS free versions are live! (Gen:12)
- New RISC OS !FamTree application reviewed (News:1)
- Returning to ImpressionX (News:)
- RISC OS interview with Richard Keefe (News:2)
- South West Show is fast approaching (News:4)
- January News Round-up (News:)
- NetFetch reaches Version 5 (News:1)
- Primesolve (PP:12)
- RISC OS FR : The Raspberry Pie contest (News:23)
- Destiny Hints and Tips
- Doom - Level Walkthroughs
- Syndicate cheats
- Doom - MegaWAD Reviews - Star Wars TC
The Icon Bar: News and features: SunBurst hints, tips and walkthrough
Hints & Tips
    not be destroyed.
Walkthrough
  1. Set course to Research 1
  8. Kill Death and Famine.
  10. Destroy War.
    Hyang.
    the Hyang.
  23. Head back to Oasis.
  27. Catch the Hyang again.
    ships!
  31. Head to Nimbus.
  33. Upgrade!
  36. Destroy the 4 'spikes'.
  42. Head to the launch site.
Cheat codes
CASH5000 extra credits.
SunBurst directory.
  (15:58 11/12/2000)
  Owain Cole (12:54 12/9/2001)
Dave
Owain Cole Message #87879, posted at 12:54, 12/9/2001, in reply to message #87878
