- Loads of Acorn / BBC Micro stuff (Gen:6)
- RDPClient Riscos 6.20 (Gen:24)
- Can someone look at this ARM code for me? (Prog:6)
- Help save my old RiscPC (Gen:12)
- RPCEmu 0.8.7 (Gen:1)
- Games that require courage (Games:7)
- Beeb porn (Gen:2)
- Viewfinder 1.1 (Gen:3)
- http://www.acorncomputers.com/ (Gen:21)
- Best free RISC OS games! (Games:111)
The Icon Bar: News and features: Building the Dream 1 - Container data structures
Posted by Jeffrey Lee on 12:00, 15/7/2007 | , ,
Arrays
Linked lists
Differences
Very quick and very slow
Abstract data types
List-based ADTs
Maps
Sets
Trees
Priority queues
  andrew (17:16 15/7/2007)
  mavhc (22:48 15/7/2007)
    Phlamethrower (23:05 15/7/2007)
  adamr (19:38 3/8/2007)
    Phlamethrower (20:59 21/8/2007)
      MikeCarter (08:27 22/8/2007)
        Phlamethrower (09:48 22/8/2007)
          Phlamethrower (12:03 23/8/2007)
Andrew Message #103521, posted by andrew at 17:16, 15/7/2007
HandbagHandbag Boi
Wow shock Nice idea.
Mark Scholes Message #103527, posted by mavhc at 22:48, 15/7/2007, in reply to message #103521
Jeffrey Lee Message #103529, posted by Phlamethrower at 23:05, 15/7/2007, in reply to message #103527
Adam Message #103730, posted by adamr at 19:38, 3/8/2007, in reply to message #103521
Adam
Jeffrey Lee Message #104052, posted by Phlamethrower at 20:59, 21/8/2007, in reply to message #103730
Mike Message #104058, posted by MikeCarter at 08:27, 22/8/2007, in reply to message #104052
MikeCarterOooh fruity!
Jeffrey Lee Message #104059, posted by Phlamethrower at 09:48, 22/8/2007, in reply to message #104058
Jeffrey Lee Message #104076, posted by Phlamethrower at 12:03, 23/8/2007, in reply to message #104059
